I know this has been asked a couple times, but I am trying to figure out the paint code for this car. I looked in the glove box, that didn't help. It is a purple 96, so it seems pretty rare. Thanks.
Paint Codes
it'll be on one of those little white stickers, that have all the rpo codes for your car. have you found the stickers? you can't miss 'em, honest :D
soemtimes they're in the glovebox...mine are on the inside of my driver's side door. also check the inside of the passanger side door & inside your hatch. they're supposed to be easily visible.
--matt
I have only found the one that is in my glove box. It is probably 4"x6" and has all of the 3 digit codes on it. I checked the door jams and don't remember finding anything there. I will check the hatch tonight when I get out of work. Thanks a lot!1996 Camaro w/ Y87 package. T-Tops, purple, loaded. Custom painted salad-shooters with Mirage paint.<br /><br />(It\'s my girlfriends car!)
I found two stickers on the driver's door and the one in the glove box. The one in the glove box has maybe 50 3 digit codes on it, none of which seem to be a paint code. On the driverside door, one sticker has tire information and the other vehicle weights and the like. None of the codes I found look like paint codes. Any ideas?1996 Camaro w/ Y87 package. T-Tops, purple, loaded. Custom painted salad-shooters with Mirage paint.<br /><br />(It\'s my girlfriends car!)
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...3 weeks ago
