Looking for a pic of a black 98+ BIRD with y87 bumper - FirebirdV6.com/CamaroV6.com Message Board
  • Looking for a pic of a black 98+ BIRD with y87 bumper
    If you have it, post! Got a cheap offer on a black T/A bumper and I may snatch it up.
    Thanks
    They are probably not compatible..
    The Trans Am and Firebird/Formula front ends are different... Might as well keep the Firebird front end, and just get some WW ground effects... or somethin..
    <b>« Red <i><a href=\"http://sandman.v8tec.com\" target=\"_blank\">Firebird</a></i> »</b>
      A y87 has the exact same bumper as a regular bird. Y87 is just performance (v6). And if your talking about the front bumper (fascia) I'm pretty sure it'll fit, I've seen someone with a 97 or prior bird with a T/A front fascia on it, you'll probably have to get new fogs and what not. It also might look odd because the T/A fascia is lower because the ground FX are basically built in so it won't line up with the middle of your car. If your talking about the rear bumper you'll have the same problem but they should bolt up. How much of a pain it is to remove the bumper and put a new one on, I have no idea
      1998 Red RS 3.8l A4<br /> Whisper - K&N - N20 - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br /> Removed grille - Limo tint - blackouts - A-pillar cf a/f ratio<br /> Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
        front or back bumper? if its the front it will look messed up without the side skirts, if its the back then it will work and not look bad it will make it look level just fyi
          hmmmmmm, does anyone have a pic of a t/a rear bumper on a plain bird.. i've been thinkin bout doing that for a while now...
          MODS. (small yet noticable)<br />-Dynomax exhaust<br />-umm, custom intake lid & air silencer w/K&N (Cheap!)<br />-T/A rear bumper
            Sorry guys, I meant REAR bumper.
            Thanks.
