i have mine mounted on my air dam. two holes in the plate itself, half way up on each side, then bolted to the bottom edge of my air dam.
can't see it if you're stand right near the car, but if you're like 15' feet away, you can easily see it. the further away you are, (like across an intersection) the more normal it looks. i've had no probs with the cops here...it's "visible from the front"
<blockquote>quote:</font><hr>Originally posted by awesomeame: i have mine mounted on my air dam. two holes in the plate itself, half way up on each side, then bolted to the bottom edge of my air dam.
--matt<hr></blockquote>
yeha i know a few people that have it there in illinios that have been ticketed for it.. not sure what the offense was , but one of the cops told my friend that if he had it off he probably would have just ignored it.. but since it was on the airdam he gave it to him..
i couldnt find any good ones, but ill go right now and get some better ones. its on the car so it wont be real easy to see. but youll get the idea. ill upload them tomorrow when i get back to school.
here are some of them. theyre not very good. i must not have been holding the camera very steady. its pretty muct two 2 inch by 3 inch pieces of extremely thin steel bent with holes drilled to fit correctly on the plate and the pre drilled holes in the grill. the dark square looking things at the bottom of the plate keep it from bouncing off the paint. they are actually just a couple of those foam things that the dealerships put on the bumpers of their cars and poles on their lots. very sticky on the back and nice and foamy. ITs not very sightly right now, i normally wrap black vinal around the bracket to keep it from being seen. this time i but it on and just covered it up a bit. i take it off at the shows anyway. i just have to have a plate here in missouri.
[ January 14, 2004: Message edited by: Loochy88 ]</p>
