Blacklight Neons :P - FirebirdV6.com/CamaroV6.com Message Board
Blacklight Neons :P
  • Blacklight Neons :P
    I have them in the car... just need to wire the switch. Can anyone help me? I tried electronics but its dead and I want to do this tonight.
    I want to put the switch between the shifter and the cup holder (97 console). Where is the closest power source to that and can u be specific as to what I am looking for.
    Thanks
    From my experience, all switches need to be wired to the battery........
    <a href=\"http://members.cardomain.com/leonwithneons\" target=\"_blank\">1997 Grand Prix GTP</a>
      yeah thats what I am going to end up doing. how does that work though?
      Do u know of a diagram? I do want to make sure its right.
        the only advice i have is do't let the wires show and also put an inline fuse between the device and the battery. this will save u atleast hundreds if somehting shorts out. it happened to a friend of mine blew his whole computer next tiem he will listen to me i guess.
        Gmoney<br />95 firebird 3.4l engine<br />Alpine speakers and Alpine 300 watt amp, bazooka bass tube<br />custom lights and switchs<br />window tinted<br />flowmaster 80 series exhaust<br />Custom Firebird cutout<br /><a href=\"http://hometown.aol.com/ibinlinkinpark/FirebirdCutout.html\" target=\"_blank\">http://hometown.aol.com/ibinlinkinpark/FirebirdCutout.html</a>
          Here are some diagrams that were made by a guy I sorta know named Carl. They're pretty good, but the only thing that helped me out was finding a guy that knew what he was doing, and having him help me. [img]tongue.gif[/img]
          http://www.cmeglow.com/wiringdiagrams.html
          Good luck.
            You can get 12 volts from the cigarette lighter. just take off the panel and cut into the wires that goes to the cigarette lighter. Black is gnd.
            1997 Camaro Y87. Turbo.<br /><a href=\"http://pureoctaneracing.net/\" target=\"_blank\">Pure Octane Racing</a>
              <blockquote>quote:</font><hr>Originally posted by ChronoGN:
              You can get 12 volts from the cigarette lighter. just take off the panel and cut into the wires that goes to the cigarette lighter. Black is gnd.<hr></blockquote>
              or instead of cutting, simply splice into it. Wire taps are cheap.
              2002 5-spd NBM Camaro
              Details: www.1lev6.com
                If you splice into the cig. lighter wire, make sure you watch out about overloading the fuse. Since the cigarette lighter and the horn are on the same fuse, I blew a fuse out by having a cell phone charger plugged in and using my horn at the same time.
                  Per my post in Electronics, I recommend wiring it to the junction block on the passenger side fender under the hood. Put a circuit protection fuse 6" or less from the source in the new wire, and fuse it for the wire, so if it's 10 guague, put a 30 amp fuse, regardless of what the neons draw. You can fuse smaller at the point the neons come in. Then if it's a really high current draw, you will want to use a relay to switch them on and off.... if it's a lower current draw then you can get away with an inline switch.
                  What is the current rating for those neons, do you know? If you don't can you find out what size fuse they come with???
                  Thanks!
                  -Mike
                  <b>Trucks</b> <br />\'05 Dodge 3500 Dually <i>Cummins Turbo Diesel</i><br />\'98 Dodge 2500 4x4 <i>360 V8 (Wife\'s)</i><br /><b>Toys</b><br />\'81 Chevy K10 <i>Stroker/Swampers/Custom Suspension/1-Tons/Beadlocks</i><br />\'99 Camaro Z28 <i>6 Spd, T-tops, Borla</i><br /><br /><b>Real trucks don\'t have spark plugs</b>
                    they are cheap neons... i dont' know the specs specif. but i got them from target [img]smile.gif[/img]
                      lol...dont bother putting them in...you'll eventually get tired of them as I did...but ya buy wire taps asnd splice off of the cigarette lighter....
                      05' CTS-V
                      00' Camaro - SOLD :(
