does anyone know how to make the switch box to take the place of the ash tray. I have a 01 and would like to put in a swtich box in my ash tray, but I have no experience with fiberglass or anything. Just wondering if y'all could lend me a hand
EDIT
sorry, this is in the wrong place... I thought I was in stero/electronics
[ July 26, 2002: Message edited by: MrCoffee ]</p>
All i did was get a scrap piece of sheet metal and i took dremel and measured out the length and width of the switch and cut the hole. Then i took out the ash tray and placed the sheet metal there to see if it would fit. It took a couple of tries to get it perfect because of the hinges for the ash tray cover. once i had it perfect i took some screws and put two screws on each corner at the bottom then i took out the sheet metal again and painted it black and clear coated it. put the switch in, wire it up, screw in the sheet metal. That was all i did.
Hey acidragon take some pics of that for me. What I did was use the existing ash tray cover, drilled holes in it for my switches and LEDs. It looks pretty sharp. You might want to consider that.
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
