'01 Dash Removal - FirebirdV6.com/CamaroV6.com Message Board
'01 Dash Removal
  • '01 Dash Removal
    I painted the for vent on my 01 Firebird Dash. However, I couldn't get the dash out, so the job is only half done. Does anybody know how to take the dash out? (I am talking about the piece from he windshield toward the driver.) I tried to pry in various locations but that didn't seem to work. So I need to unscrew the side pillars first on the inside? Somebody on here told me to pry to get the air vents out. Well that didn;t work. Lucky my car was under warranty at the time, but the car is no longer on warranty if I crack my dash.
    Thanks
    Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
    Are you talking about the biggest piece that touches the glass and goes all the way across?
    I solemnly swear I am up to no good.
      Uh-huh
        A big screw driver a patience. It's held down by the same plastic/velcro type things that hold everything else.
        Good Luck
        2000 Camaro Z/28
          This thread tells how to remove and replace the big dashboard panel IF you have t tops (or a vert, I guess):
          http://www.camarov6.com/cgi-bin/ulti...c;f=5;t=006710
          If you have a hard top, then I suggest you look at www.LS1.com or www.Ls2.com in the appearance sections. I recall seeing some discusions there about removal for hardtop f bodies.
