I'm considering installing some gauges in my 97 Bird in the three central air conditioning vents and leaving the farthest vents open for normal A/C. With the three center vents closed the air will blow harder out the ends instead and I can install oil temp, tranny temp, and air/fuel gauges from summit. I measured the opening size and it seems to be nearly 2 5/8" on the dot so this might turn out well. I will post some layout pictures when I get some time soon.
Firebird In-Dash Gauges (Use 3 Center A/C Outlets)
C. Boney<br />1997 Firebird 3.8L V6<br />---------------------<br />Modifications:<br /> <br /> SLP Cold Air Induction, Ported/Polished Throttle Body, Carsound 3\" High Flow Cat, Sweet Thunder 24\" Chambered Muffler, Removed Rear Exhaust Section, Custom Fan Switch, 35th Anniv. Silver Stripes, Old T/A-Style Silver Sail BirdsTags: None
