A Couple o' Questions - FirebirdV6.com/CamaroV6.com Message Board
  • A Couple o' Questions
    Got my new car recently ;)
    So I get my car home, and screw off that dealer plate... only to figure out... I'm not unscrewing it from standard pre-made holes... I'm unscrewing it from my ground effects which they SCREWED IT INTO ARRRRGGG... It's not THAT big of a deal but you'd think they could be a bit more creative with their front plate than that.
    #1. What should I use to fill those holes?... Just use puddey and touch-up paint or what?
    #2. When I took off the front plate-holder thing... and cleaned the mud off from where it had gotten under, I noticed that there was a noticable difference between where the plate backing had been, and the surrounding paint. I ran my finger across it, it felt like tar or something. How can I get this off? Will clay bar get it all? I plan on ordering the Zaino kit today.
    My bro suggested black silicone (mah car is black), but I know you can't paint silicone, so I don't want to put it in there, then find that it looks bad and be in a fix since I can't paint over it.
    Anyone?.... It seems like someone on here must've had this problem or something similar.
    [ August 19, 2004, 11:28 PM: Message edited by: Loochy88 ]
    Black 1997 Camaro RS<br />Mods: Headlight, Fog Lamp, Blinker, and Tail Light Blackouts<br />35% Tint Window Armor (www.windowarmorusa.com)<br />Upcoming: Replace failing driver\'s window motor and Black Power Antenna<br /> <a href=\"http://members.ca
    i'd just fill the holes in with bondo or something like that...sand it smooth...and paint over them...i had to do this when i removed the front section of rksport's kit...as far as that tar-like stuff...im not sure...try goo-gone?
      WD40 works but I'm not sure how bad it is for your paint(for the tar stuff).
      On the other, bondo and paint.
      2005 Ford Focus ZX3 SE D20 M5 - Modified ;) <a href=\"http://www.knightenmotorsports.com\" target=\"_blank\">http://www.knightenmotorsports.com</a> <br />[ U R L = h t t p : / / w w w . g e o c i t i e s . c o m / h e a r t l a n d _ h e a t _ v 6 ] Heartland Heat V6 [ / U R L ]
        k, thanks! I don't think goo gone will get tar... I guess I could try, but I'm claybarring my car soon and hopefully that will get it all. If if somehow doesn't get it all I'll try alternative solutions.
