Fog light troubles - FirebirdV6.com/CamaroV6.com Message Board
Fog light troubles
  • Fog light troubles
    While replacing my fog lights this evening in the garage I decided to not unscrew the bottom of the car and instead take out the plastic pins that hold the fog light into the assembly. Successful at changing the bulb through the front I then decided to drop one of the pins inside my car. :(
    Does anyone know where I can get another one of these 2 piece plastic pins so I can put my light back together 100%?
    95 3.4L <br /> <a href=\"http://www.myspace.com/1277388\" target=\"_blank\">http://www.myspace.com/1277388</a> <br /> <a href=\"http://www.cardomain.com/profile/altspacen\" target=\"_blank\">http://www.cardomain.com/profile/altspacen</a> <br /><a href=\"http://groups.myspace.com/camarov6\" target=\"_blank\">http://groups.myspace.com/camarov6</a>
    why cant you get to it? where did you drop it?
    2000 3.8 A4 Pewter Camaro
      couldn't u just take off all that blk plastic screwed to the bottom of your bumper and look for it there?
      99 WS6
      13.25@104.97 - Lid + soon to be more other stock items ;D
      Originally posted by camaroextra
      tears are great lube, but its hard to get a girl to cry onto her own ***.
        i dropped it inside the nose of my car and i don't want to go taking my lower front end apart to find a little plastic piece
        my arm won't fit inside the bottom of the car to get to the front point where the piece is lying
          slice your arm a few inches.then you should be fine :D
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
