Hey, I just got a Fiberglass Hood without any insulation panel and I've heard that if you paint it without one the paint is going to warp becuase of the heat. Is this true???
Do Fiberglass Hoods Warp??
mine hasnt warped, i heard the maccham if thats how u spell it are bad for warping but my hoods fine i got the predator ram air one from sun coast creations is doing fine with out the insulation, i thought that was manly for smoothering fire for the most part i kno its a heat shield too but i think its man factor is for fire but i could be wrong i kno it does play a roll in smootherin a fire under the hood94 Pontiac Firebird-V6<br />-NxWetKit,RamAir,MSD Dis4, Coils,&Wires,DynomaxExhuast w/testpipe,NittoDR\'s&DunlopSPort5000s,17\"CrEagleAl loys,TransgoShifKit/VetteServo<br />91 Jeep Wrangler-5.7 Chevy350<br />-6\"ProComp SuspensionLift,M/T BajaClaws35x12.5,& more goodies
ive never heard of the mecham warping. the best way to tell if it will warp is to look at the underside of the hood. If it pretty thick and has a lot of bracing like the stock hood it will usually be fine. The people that usually have the problems are the import guys that get the cheap hoods that have no bracing at all. I have a fiberglass fabricators ram air hood and it has had no problems, and it is considered an off brand2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
Originally posted by andrew N.:
the mecham hood is so expensive, that sht better not warp.I guess I\'d have answer your question with another question.<br /><br />How many Abidiginals do you see in modeling??????<br /><br />headers, 3inch magnaflow cat, Loudmouth<br />99 Midnight Blue Firebird<br />3.8L A4
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...2 weeks ago
