How do you remove the door panels in an '01 firebird? Is there some sort of double sided tape holding the edges nice and tight? I dont want to use too much force I'm just getting annoyed I cant get them out.
01 firebird door panels
How do you remove the door panels in an '01 firebird? Is there some sort of double sided tape holding the edges nice and tight? I dont want to use too much force I'm just getting annoyed I cant get them out.01 Firebird <br />Whisper Lid - K&N<br />Raised Air Lid - Free Ram Air<br />Borla Cat-Back Quad tips<br />3.42s with lsd on the wayTags: None
Let me know if someone tells you because I would like to know myself. I have heard it is hard to remove them and once you do they are very hard to get back on because of some kind of tabs that break :(
-Michelle2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
i have a 99 and it wasent all that hard, yes there are tabs at the bottom of the door and 5 screws you have to take out, one of them is behine the window controls. Hope that helps a little bit. Sorry if it does notMike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
Yeah, make sure all of he screws/bolts are out. Then you'll just pull UP on the panel, not out. I suggest everyone pick up a Haynes manual cause it will tell you how to basically take the whole car apart ;)~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
<blockquote>quote:</font><hr>Originally posted by Dojo2000:
Yeah, make sure all of he screws/bolts are out. Then you'll just pull UP on the panel, not out. I suggest everyone pick up a Haynes manual cause it will tell you how to basically take the whole car apart ;) <hr></blockquote>
Haynes is the man.
All screws, pull up and out. First thing you remove is the mirror backplate and the doorhandle/lock plate, then the whole panel lifts out :D Easy sneezy.2002 5-spd NBM Camaro
Details: www.1lev6.com
