01 firebird door panels - FirebirdV6.com/CamaroV6.com Message Board
  • 01 firebird door panels
    How do you remove the door panels in an '01 firebird? Is there some sort of double sided tape holding the edges nice and tight? I dont want to use too much force I'm just getting annoyed I cant get them out.
    01 Firebird <br />Whisper Lid - K&N<br />Raised Air Lid - Free Ram Air<br />Borla Cat-Back Quad tips<br />3.42s with lsd on the way
    Let me know if someone tells you because I would like to know myself. I have heard it is hard to remove them and once you do they are very hard to get back on because of some kind of tabs that break :(
    -Michelle
    2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
      i have a 99 and it wasent all that hard, yes there are tabs at the bottom of the door and 5 screws you have to take out, one of them is behine the window controls. Hope that helps a little bit. Sorry if it does not
      Mike<br /><a href=\"http://www.my99firebird.gq.nu\" target=\"_blank\">www.my99firebird.gq.nu</a>
        Yeah, make sure all of he screws/bolts are out. Then you'll just pull UP on the panel, not out. I suggest everyone pick up a Haynes manual cause it will tell you how to basically take the whole car apart ;)
        ~Derrick <a href=\"http://www.appstate.edu/~do54457/\" target=\"_blank\"><i>My Webpage</i></a><br /><b>\'96 3.8L V6 M5 Firebird Y87</b> | <b>162.8 RWHP</b> / <b>196.7 RWTQ</b> <br /><b>•</b> SLP CAI <b>•</b> <a href=\"http://tech.firebirdv6.com/y87.html\" target=\"_blank\"><b>Y87</b> Package</a> - 3.23s <b>•</b> 180º thermo w/ fan switch <b>•</b> TB spacer from DEE<br />1991 Jeep Cherokee Laredo 4x4
          <blockquote>quote:</font><hr>Originally posted by Dojo2000:
          Yeah, make sure all of he screws/bolts are out. Then you'll just pull UP on the panel, not out. I suggest everyone pick up a Haynes manual cause it will tell you how to basically take the whole car apart ;) <hr></blockquote>
          Haynes is the man.
          All screws, pull up and out. First thing you remove is the mirror backplate and the doorhandle/lock plate, then the whole panel lifts out :D Easy sneezy.
          2002 5-spd NBM Camaro
          Details: www.1lev6.com
