I just got a set of 17" polished 5 star rims off a 1997 WS6 trans am... they are pretty sweet. I just bought new tires for the rims..
TOday i went to tire store and they told me those rims WON'T FIT!!!!! WTF!! the rims center hole is little small to fit... anybody knows what the hell is wrong??? i paid like **** load $$$$ and they don't fit??? what shoud i do???
You need to take a file and grind down the hole where the wheel hub sits, you only need to remove a small amount of material. I had the same problem fitting my 02 SS wheels on my 95 Camaro
Maxmsu,
I had the same EXACT problem trying to fit 2000 Trans Am wheels on my 1995 Firebird. I went to a tire shop as well and when they told me it wouldn't fit I almost cried. The idiot working their told me there was nothing I could do :eek: .
So I came home and took a look for myself. After a little observation I found out it was caused because I didn't 4 wheel disc brakes like the 1996 and up f-doby's do. Basically the center hub on our the rear drum brakes are alittle to big to fit the newer rims.
This is what I did. I just took a dremel and a stone grinding bit and just grinded the inside lip of the rim until it fit. It dosen't take much(about 1/8 inch). You don't need to this to all four wheels just the rear two. If you need more help just tell me, although it's very easy. ;)
[ December 12, 2002: Message edited by: fbody4life ]</p>
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
