questions?? - FirebirdV6.com/CamaroV6.com Message Board
questions??
  • questions??
    Im getting 9" eurolite mini tubes for my interior for christmas. I have some questions.
    1. Do I need a inline fuse for these lights??
    2. Does anyone have the website that has the diagrams wiring the lights?
    1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
    I am not sure about the wiring diagrams, but as for the first question... fuses good. If the lights don't already come with fuses, put some on. It might just save you some prollems in the future.
    Rob
    \"A one that isn\'t cold, is scarcely a one at all\" <a href=\"http://www.homestarrunner.com/sbemail.html\" target=\"_blank\">Strongbad</a>
      i dont know if there is a fuse or not..the lights go into this little black box thing and then it goes out to the cigarette lighter adapter.
      do you think thats the fuse?
      one more question,,,im gonna put a switch in instead of the cigarette lighter thing,,
      when i cut the wire, how do i know which wire if for the ground and which wire is for the power?
        Ahhh, one of those. Well the good thing about pluging into the cig lighter is that it has its own fuse. There is prolly a fuse in the plugy thingie that goes into the cig lighter. Are you going to use the power from the cig lighter... like just using the wires from the back of the lighter? That will still tie into the cig lighter fuse, but that might just be too much of a fuse and might blow the lights before the fuse pops. See if there is a fuse in the cig light plug thingie, and if there is any splicing going on, put an inline fuse of the same size.
        Rob
          what brand is it if its light glow when you shed the wire of the covering the power wire is copper and the ground is silver. as far as a switch goes mine are wired into my fuse panel then routed to a switch so when the car is off they wont come on.
          no fate but what we make<br /><a href=\"http://www.cardomain.com/memberpage/748167/1\" target=\"_blank\">http://www.cardomain.com/memberpage/748167/1</a>
