Installed Gauges TACH STUCK - FirebirdV6.com/CamaroV6.com Message Board
  • Installed Gauges TACH STUCK
    I ordered the silver reverse gauges from procarparts and installed them today. I ran into two problems. The first one is that the tach needle is stuck at 3000. I will take it apart and see if some super glue or something will help. My other problem is that whenever the headlights are on I now have a ptched sound coming through my tweeters. I suppose I will try moving the ground location and see if this helps. Any other suggestions are welcome.
    1995 Pontiac Firebird 3.4L <br />TA front bumper, TA rear bumper, 98-02 Honeycomb tailights, GM Ram Air hood, 2k C5 18X9.5 Corvette rims all the way around, custom autoloc shaved handles, camaro two tone interior, silver badging, clear front marker lenses, RK sport headers, gutted cat, dynomax dual exhaust, Rear disc rearend, Richmond 3.73 gears, Zexel torsen LSD, Cross drilled front rotors, 2 12\" MTX thunder 8000s, Clarion 400W amp, MTX 5 1/4 <br />Components, thunder 4262 amp, pioneer head unit, Hypertech power programmer (Yes it does exist)
    I installed mine (for 93-97) a while ago... no information from others were available that time. so i have to took everything apart to figure it out on my own... yeap you have to super glue that ... it didn't fit 100%... my needle got stuck too... i havet o super glue the edge of the gauge around the base of the needle... PITA!!!!
    Anwyays, if you have any other question let me know i guess i am the only one here can help ya :D
    TECHNOBETSY
      Mine got stuck last night, but then I removed the original over lays and slapped the indiglo ones on. The original black ones peel right off, only tape holds them.
      <a href=\"http://www.xbox3604free.com/default.aspx?r=381546\" target=\"_blank\">http://www.xbox3604free.com/default.aspx?r=381546</a>
