As many of you know the top dash area nearest to the windshield at times will crack due to intense heat [img]tongue.gif[/img] . Well mine unfortunately was crack when the first owner screwed in a big *** tachometer on to that part of the dash, My question is can i replace that part without taking the whole dash apart.A guy at the shop told me he would do it for 500 and i said he was nuts cause i can take like 70% of the dash off myself. Thanks.
Help with Replacing dash
It is easy if you have T-tops and harder if not. With t-tops, the pillar covers can be easily removed, thus allowing easy removal of the dash cover.
Do you have T tops?I solemnly swear I am up to no good.
Here is a cut and paste from a post I made at www.ls1.com (if you want to see the entire thread, go to www.ls1.com and search for Dash Crack in the Appearance Section):
The big plastic dash panel that goes from each side up to the glass is GM part # 10410583.
If you have T tops, it is easy to replace. You first remove the pillar covers (two screws at the top of the pillars). Then remove the pillar covers. The dash panel then lifts out (it hooks under the pillar covers and also has several snap-in areas underneath).
The intense sun here gradually made mine more brittle and it cracked one day. The cracks got worse.
I paid $86.66 at www.gmpartsdirect.com.I solemnly swear I am up to no good.
Take the t tops out and you'll see the two screws at the tops of the pillars. They unscrew with a Philllips screwdriver. Carefully pull the pillar covers off.
DON'T pay $500!!!!I solemnly swear I am up to no good.
Originally posted by SilentV6:
Yes, i do. I know there are like some pins holding it down because i cant seem to pull 2 piece out that is nearest to the windshield
One of those "pins" broke off on mine, so be sure you get them all out. When I was trying to install my replacement, I could not get it to go down in one spot. then I realized one of the broken off "pins" from the old dash part was still in its mounting spot. [img]graemlins/slap.gif[/img] doh!I solemnly swear I am up to no good.
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...6 hours ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...3 weeks ago
