mounting neon lights?? look!! - FirebirdV6.com/CamaroV6.com Message Board
  • mounting neon lights?? look!!
    I want to put a neon light on the hump between the rear seats.
    is it alright to put a small screw into that hump area or is there anything under there that i should worry about??
    1995 Camaro 3.4L<br />dynomax super turbo muffler<br />SLP CAI<p>It\'s red so it must be fast!!!
    <blockquote>quote:</font><hr>Originally posted by thabomb180:
    <hr></blockquote>
    The screw might puncture the driveshaft :cool: j/k
    Nah, you should be fine. Maybe just attach it to the carpet with a nut and bolt with a washer on each side. That way you won't have to drill through the car.
    -Andrew
    1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
      but how would i get under the carpet to put a washer and bolt???
        just put the hook side of velcro on the neon light and slap it on- when you need that space just yank it.
        -Justin-<br />Red 1996 Camaro RS- Wrecked 11-1-03...<br /><br />1991 Camaro RS
          I had done this for awhile, and just used double stick tape. It worked fine on the carpet, then when i got tired of it was just able to remove it.
          1998 Firebird w/ LS1 & A Few Mods<br /><br />Pictures--&gt;<a href=\"http://www.fad2blk.smugmug.com\" target=\"_blank\">www.fad2blk.smugmug.com</a>
