Is Zaino really worth it??? - FirebirdV6.com/CamaroV6.com Message Board
  • Is Zaino really worth it???
    i'm fixin to spend $100.60 on Zaino.
    -ZFX
    -Z2
    -Z5
    -Z6
    -Z7
    -Z12
    -Z16
    i know it's the best...but is it really worth it???
    Yes.
    You will also need to use some 100% cotton towels if you don't have any.
    If I may ask, why are you buying so many products?
    Edit - you don't have to buy all of those.
    You *need* ZFX or Z1 not both
    You Need Z2 and/or Z5
    Recommended to get Z6, Z7, Z18
    [ September 30, 2002: Message edited by: The Sandman ]</p>
    <b>« Red <i><a href=\"http://sandman.v8tec.com\" target=\"_blank\">Firebird</a></i> »</b>
      i need some more tire gloss and window cleaner anyways...figured i might as well buy the best. and as for Z18...i already have a mothers calybar, so i can't see how there can be that much difference.
      any more info is welcome. ;)
        That claybar is fine, as long as it is not the red abrasive kind.
        The Z16 tire gloss won't make your tires super shiny, but it isn't gooey either. They will have a nice soft satin look when they are done.
        The window cleaner is a mild abrasive, so unless you have some really stubborn hard water stains, I'm not sure if you need to use this. It won't hurt either way [img]smile.gif[/img]
          There isnt a wax in the world worth that much.
          Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
            <blockquote>quote:</font><hr>Originally posted by SLOWBRAEATER:
            There isnt a wax in the world worth that much.<hr></blockquote>
            actually i have used zaino before and yes it is worth that much money. that is the best around
            <b>2000 Firebird </b><br /><i>old setup </i>- Automatic Whisper lid, Borla catback, shift kit w/ V8 servo, 3.42 gears w/ LSD, PI 3000 converter, <br /><br /><i>14.703@90.92, 2.01 60\' </i>(intake and exhaust)<br /><br /><i> new setup </i> swapped over to LS1 413.9rwhp/398.7rwtq<br /><a href=\"http://www.thunderracing.com\" target=\"_blank\">www.thunderracing.com</a>
              Zaino isn't a wax. Please know what you are saying before you say something dumb [img]smile.gif[/img]
