Anybody know where I can find the attaching plastic clips/retainers that hold the passenger and driver's side lower OEM ground effects on my 96 RS? There are 8 on each side. They are rectaingular about 2 inch X 1/2 inch thick with a blind entry point that goes into a hole in the body.
I took the old one to GM and they no longer make them and the replacement requires drilling into the body and pop-riviting a metal piece onto the body. It doesn't seem right. Someone has to have some out there. Let me know.
2000 camaro rs:whisperlid, 2.5 magnaflow exhaust, catco high flow cat, fast toys cai, 3.73, 160 power stat, msd 8.5 wires ngk iridium spark plugs, hpp3, zzp w/p and alt. under drive pullies, 1.9 Rockers/LS6 Springs with ls1 retainers
