Window Washing??? - FirebirdV6.com/CamaroV6.com Message Board
Window Washing???
  • Window Washing???
    I clean my car alot but there is one thing that I can never get to look good! The windows I can never get to be nice and clean. Mine always have streaks and when I try to see out of it its really bad! I dunno what to use to get the windows nice and clean without all the streaks that make it hard to see out of... So is there anything I could use that would make it look better? I need help!!
    -Derek
    Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
    windex!
    seriously, after you wash the car dry the windows off really good. Usually you can just do it with a chami and then go over it with another dry cloth and the windows will look great, but if you want them to be really really clean, use windex after the windows are dried.
    just don't use them on the inside if you have tint. To clean the tint, just use water and a wash cloth, then dry it up so its not streaky.
      I do use windex! It makes it like that! :(
        I don't know if this is a crock of crap or whatever, but I heard newpaper is great on windoww... I haven't tried it, so I don't know.
        2002 Silver Metallic A4 Firebird - All Options
        Hotchkis STB, Custom Madrel Bent 3" Exhaust, Pacesetter Headers, Whisper Lid, FT Ram Air, K&N Air Filter, D2S HID, Baer Rotors, !EGR, !MAF, 10% tint, Parrot CK3300
        Your Mom or My Dad?
          newspaper does work.
            Yep, newspaper. That's ole school!
            Never used it on tinted windows though. Don't know if it will scratch or not.
            My fake chamois from autozone does it good enough.
            [ April 12, 2003: Message edited by: AMinor65 ]</p>
            <b>1998 Firebird 3800 Series II, A4</b><br />Direct-Flo Lid,K&N Filter,DEE TB Spacer,TPS-TEC,ZZP Mini-AFC,Raised and Cutout Airbox 7mm,BMR STB & Boxed LCAs,KYB AGX Shocks,Drilled/Slotted Rotors,180* Thermo,2.5\" Catco Cat,Dynomax 2.75\" custom catback,Kumho Ecstas/245,Jet Stage 2,3.42,Edge Racing 2870 Stall,B&M Tranny Cooler,B&M Deep Tranny Pan,LSD,AAM Girdle,1LE DS,NX Wet Kit,MSD DIS-4,MSD Blaster Coil Packs,Taylor Spiro Pro 8mm Wires,NGK TR6\'S gapped .045,ZZP UD WP Pulley,SLP Fan Switch,TT II\'s<br />N/A: 15.6342 @ 88.44 (On stock converter. Strugglin\' to beat it.)<br />Nitrous 50 Shot: 14.7463 @ 93.49
              FYI its "Chamoi" but, try cleaning your windows with a clean terry-cloth towel, out of direct sunlight, and ensure the glass surface is cool to the touch.
              Newspaper doesn't work any better than a towel, and if you think newspaper is good on glass - try rubbing newspaper between your hands and then look at them...that black stuff that rubbed off is ink, that you are now applying to your windows. So you trade streaks for an obstructed view????
              <b>15.41</b> @ 89.80 & 15.45 @ <b>91.64</b>, 2.21 60ft, 3,440 raceweight, using <b>OEM</b> Equipment. <br />\'98 L67/M49 w/ 134,000 miles before spun bearing. \"<i>It\'s all stock, Baby</i>!\"
                FYI, FYI it actually is Chamois or Chamoix.
                Newspaper ink does rub off on your hands, but for some strange reason (sorry I'm not Mr. Chemist)it doesn't smear on windows. Don't imagine that the tiny scratches can be good for the surface over the long run.
                <a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
