My tint which is only like a few weeks old is starting to peel at the top in one spot on my driver side window. Is there anyway to reglue/seal it back up? It's only a litle lip forming, but i just dont' want it to get worse? I had this same window done over 3 times already, and really don't want to take it back again. That window is real loose where is wabbles back and fourth, so i think it's the window causeing it, not the installer. Thanks.
tint starting to peel
1997 Camaro RS Convertible<br />White w/black top, factory chrome rims <p>Mods so far: Borla catback, Catco high flow cat,CAI,2 point STB,painted calipers and drums with caliper camaro decals,GTS blackout all the around,5% tinted windows all the way around,Streetglow red neon lights inside and under, raised camaro fill in decals on the rear, 30th anv decals, and a nice stereo system<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=275528\" target=\"_blank\">http://www.cardomain.com/member_pages/view_page.pl?page_id=275528</a>Tags: None
if the window itself is loose, you can open up the door panel and adjust the things that keep the window where it is supposed to be. They are the two things with felt on them inside the door that keep the window pushed to the right space so that the window is aligned horizontally where it is supposed to be.
if you do adjust these, make sure that that you put the one on the far edge (closest to the rear of the door) so that it isn't at an angle or too close (or both) or it might start to tear your tint over time because the felt will wear off and the remaining edge underneath will scratch and tear the tint.
hope this helps, if u need some more info, hit me up on AIM
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...16 hours ago
