Just wondering if anyone ever tried to install Trans Am rocker panels (GFX) on a firebird. Any tips or problems that anyone ran into? Got a set here in my room and trying to figure out the best way to get em on.
Installing Trans Am Rocker panels on a Firebird
Black 1998 Pontiac Firebird M5:<br />Borla Cat Back Exhaust, K&N Air Filter, SLP cold air induction, Hurst Competition Plus Shifter, Lou\'s Short Stick, Mallory , S 17\" Z06 wheels, 3.42 gears, Auburn PosiTags: None
Naw these are the side effects below the doors. They aren't affected by the front or rear bumper.Black 1998 Pontiac Firebird M5:<br />Borla Cat Back Exhaust, K&N Air Filter, SLP cold air induction, Hurst Competition Plus Shifter, Lou\'s Short Stick, Mallory , S 17\" Z06 wheels, 3.42 gears, Auburn Posi
I installed my 2 weeks ago... PITA :mad:
you need to drill lots of holes on the body.
YOU HAVE TO MEASURE THE LENGTH of each hole and use a marker to mark them... they have to be EXACT location that the little clips will be pushed into... also you need to use little screws to hold the whole piece from the bottom... you need to lift the car up... good luck.TECHNOBETSY
Im not superglueing it on to my car
maxmsu, thanks for the tips, thats probably what im going to end up doing. I might email ya if i have anymore questions on it.
[ April 14, 2003: Message edited by: Black98 ]</p>Black 1998 Pontiac Firebird M5:<br />Borla Cat Back Exhaust, K&N Air Filter, SLP cold air induction, Hurst Competition Plus Shifter, Lou\'s Short Stick, Mallory , S 17\" Z06 wheels, 3.42 gears, Auburn Posi
I forget exactly what it's called but I install lots of groundeffects where I work at, we use this rubber adhesive molding stuff (ahh i forget the name any help here?) But basically put that the edge of the sideskirts to keep it intact with the body. 2 screws should be enough to hold each side up. Just get someone to hold it and align it. It should be fairly simple.
you could use the 3M double sided tape, thats what Wings West uses to put there gfx on and then just put 2 screws on each end of the peice. Its worked great for me.1993 Camaro 3.4L M5<br />WW F-1 GFX, WW 3-pc Spoiler, Moroso CAI, Ripper, 3\" Pacesetter Cat-Back, EGR SunGuard, Taillight Blackouts, Clear Corners, Custom Painted 3rd Brake Light & Sidemarkers,<br /><a href=\"http://www.cardomain.com/member_pages/view_page.pl?page_id=384945\" target=\"_blank\">CarDomain site</a> <a href=\"http://community.webshots.com/user/grgrycamaro93-date\" target=\"_blank\">WebShots</a> <a href=\"http://www.geocities.com/grgrycamaro93/Home.html\" target=\"_blank\">Yahoo Web Site</a>
YEa thought about 3M double sided tape, but decided against it, I want something that will hold for a long time. That adhesive that Ted explained, that might be a little easier than drilling into the body, these are the actual rocker panels of a 2002 Trans Am so they are not after market like Wings West. There are plenty of screw holes available for the bottom, its just where it touches the body that i am worried, i would rather not start drilling holes in the body.
Ted, do you know where i could find that stuff you were talking about.Black 1998 Pontiac Firebird M5:<br />Borla Cat Back Exhaust, K&N Air Filter, SLP cold air induction, Hurst Competition Plus Shifter, Lou\'s Short Stick, Mallory , S 17\" Z06 wheels, 3.42 gears, Auburn Posi
you HAVE to drill holes on the body in order to put on the TA ground effects, no other alternative ways to do it... tape won't work. I tried and it fell off... 3M heavy duty double side tape.
measure the clips and mark them on the body and drill the holes CAREFULLY.
good luck manTECHNOBETSY
Now when you drilled the holes, you just drilled normal round holes right, you didn't have to make them into square holes or anything. Cuz in my shop manual it looks like the holes are square. And just one other thing, for the two bolts that go through the body towards the front, what kindof nut fits thatBlack 1998 Pontiac Firebird M5:<br />Borla Cat Back Exhaust, K&N Air Filter, SLP cold air induction, Hurst Competition Plus Shifter, Lou\'s Short Stick, Mallory , S 17\" Z06 wheels, 3.42 gears, Auburn Posi
