Remove the center console? - FirebirdV6.com/CamaroV6.com Message Board
  • Remove the center console?
    I'm interested in trying Loochy's shift boot design on my 2002.. but i'm curious how to remove the center console on my car? Anyone know how?
    Thanks!
    <a href=\"http://www.cardomain.com/id/tobescamaro02\" target=\"_blank\">www.cardomain.com/id/tobescamaro02</a><br /><br />2002 camaro 3.8 Stock with 3.42\'s.
    I assume it should be the same as my 98. In the center console/crap holder... Remove the change holder (slides right up). There are two screws in there. I believe 10mm or possibly 8mm. Can't remember. After you take those out you cant just pull the console back and out. BTW don't forget to disconnect light for the console and lighter harness...
    98 Silver Camaro V6<br />15.238 @91.74 w/ 2.288 60\'<br />Mods: K&N, FTRA, Pacesetter Headers, Spec 3 Clutch, 160 Thermo, TSP Rumbler, 3\" Catco, Whisper Lid, 3.42\'s w/LSD, Aluminum DS, Man Fan Switch<br /><br /> <a href=\"http://www.cardomain
      Be careful too, that mofo will scratch easy
      Dont call me chief.<br /><br />2001 Camaro Convertible Rs Replica<br />1991 Acura Legend
        If you're an Auto, it helps to drop the shifter back into 1st so the console slides back instead of into the dash. There's a little pin on the front of the shifter to pull the knob off, a small screwdriver should be able to pry it out.
        AIM: Alientr8tr<br /><a href=\"http://www.cardomain.com/memberpage/583450\" target=\"_blank\">1998 Camaro 3.8L</a><br />Flowmaster 80-series, !FRA, Eibach Springs, KYB AGX, SLP sway bars, 3.42/LSD, Wings West kit, Z06 Motorsports, Silverstone Metallic paint<br /><a href=\"http://www.shift5.com/\" target=\"_blank\">Shift 5</a> - My Band
        • Andy H
          Transmission removal help!!
          by Andy H
        • 2.8 Bird
          Abs inop
          by 2.8 Bird
        • fishin
          by fishin
