The passenger side skirt of the gfx on my car is starting to pop away from the car. I've looked at it and have even tried to get it to pop back in to place without any result. Has anyone else had this happen, how did you fix it. The pic in my sig shows the problem quite well.
Side Skirt Problems (W68)
1998 Firebird W68 Y87 A4<br />Raised Airbox<br />3\" Dynomax Ultra Flow CatBack<br />2800 Stall Torque Converter<br /><a href=\"http://www.tyler98w68.isask.ca\" target=\"_blank\">www.tyler98w68.isask.ca</a>Tags: None
Well the front and back ends are held on with self popers which are the plastic and metal screws. There is also 3m double sided ahesive tape plus the entire side skirt sits/hangs on a black rail rack, my guess either the tape is coming unstuck or its come off that rail rack. You need to take off the whole skirt and put it back. Take the entire side piece off then reset it. Happened to me and thats what had to happen.<a href=\"http://www.cardomain.com/id/1998firebird\" target=\"_blank\">Red 1998 Firebird</a>
I don't know about the firebirds but on my camaro there is a lip in sits in, I would pull it up and over the lip and then push down to pop it back in place. and make sure the plastic (bolts)? or what ever are snaped in place too.40th Ann GTp 4door
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
