How do I install clear turnsignals on a 02 camaro?
Ok...I bought some clear front turnsignals and tried to put them in for an hour on Monday. I couldn't get b/c of the way the stuff behind them is. I went to a local body shop and the guy said he'd have to take the entire bumper off to get to them. That sounds too expensive. Has anyone w/ a 98+ Camaro installed these that could tell me how? The factory one's have a styrofoam block on one side and a metal rail on the other keeping them in. Thanks for any help.
Rob
<b>2002 Pewter v6 Camaro</b><br />T-tops, Auto, stock GFX<br />mods: SSRA, Whisper lid, K&N filter, Borla cat-back, Pioneer HU, RF 6.5\" speakers, billet grill, clear corners, red tubing under hood, black CAMARO fill-in\'s, QTEC, GM power antenna, fan switch
Thanks for the help...my signals are at home and i'm at college, so it'll be another couple weeks before i can try it again, but i'll definately try that before i take the bumper off.
Rob
You can do it from the top, I did. Take off the headlamp assembly (there are two 10mm bolts to remove) so you can see the top of the turn signal lens. There are 3 7mm bolts holding it on, two bolt heads are facing the rear of the car, and one is facing straight down. Remove them. Once that is done, take the lens out by pulling towards the inside of the car and up. You will need to pull quite hard to get the lens to clear the body pieces that are near the outside of the lens (where it curves around towards the back). One you do it, installation of the new lenses is the reverse of removal. Hope that helps.
I went under my car to get to my signals. Just take the air dam and the other plastic thingy off under the bumper, and then unscrew the old ones, install new ones.
TIP: Put the bulb assembly in the signal, THEN install the signal! Much easier than trying to screw in the bulbs in a hole you can't see from being under the car.
1998 Black Z28<br />1995 Black 3.4 (@#$$%* ex took it!)<br /><a href=\"http://photos.yahoo.com/bc/nikkev1/lst?.dir=/New+Camaro&.view=t\" target=\"_blank\">Pics</a><br /><a href=\"http://www.scfyb.com/phpBB2/\" target=\"_blank\">Carolina Board</a>
Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...
