Resistor Questions.... Working with LED's + a question
First the question, is the bulb that goes in the shifter plate of my 97 Chevy Camaro (newer interior style) a 73 or 74?
I've never worked with LED's so my question is, with 194 bulbs and 73 or 74 bulbs what kind of resistors will I need? I did a search and couldn't find any of it. Also how do I wire in a resistor? Does it just wire in right before the bulb?
ok people, he had a bulb....
he wants to put in a led instead...
he doesnt have some led that you buy and it plugs in, just a buy by the bulk led for anything u want to use it on....
the led doesnt take the same woltage that the bulb takes..
he needs a resitor you put inline before it so that it will run correctly
I used a licence plate led in mine for what you want to do, it had a resistor wired in. You can also use one from those cheesey led window sparyers that light up, they have the resistor hardwired also.
i got mine off ebay from some bestin hong kong guys. mine were made to run at 4.4v, a car electrical system is 12v. so i used a 170 ohm resistor. got them at radio shack $1 for 5. the only thing is they dont carry very many 170 ohms.
170k ohm wont work.
then you just wire it up in line on the + side. the + side of the led is the longer end.
170k ohm wont work.
I got the LEDS and the resistors,but how do I connect them?
well you need to find out what they run at tog et the right resistor.
if you look at the led theres 2 little metal poles sticking out, ones longer. take a piece of wire cut it in half, solder the resistor in the middle. the hook it up to the longer pole. this is going to be you positive. then hook the other end up to you - or ground.
No, dont think the L.plate led's will work in the dash, it was just a quick fix for my shifter. What is it you want to do with your dash? change colors? They have straight change over bulbs for that.
