I'm going to try painting my new front clip myself. Do you think I could get away with a Urethane primer, paint and clear or do you think I should get a flex additive and spray it with a gun?
painting tips
-clean dustfree area to paint
-a couple heat lamps to help cure the paint
-wear a paper suit and resperator so you don't get any hair, body dust, (etc) on the paintjob
-like mentioned, get good paint
-wetsand before primer, after primer, & after painting before applying clearcoat
-take your time
-make many small even coats. One heavy coat will run and look like shytsigpic
the paint will hold fine and look allright without the additive, just dont expect a pretty aftermath if you bend it a bit too much.
Originally posted by CanadianCamaro:
I'm going to try painting my new front clip myself. Do you think I could get away with a Urethane primer, paint and clear or do you think I should get a flex additive and spray it with a gun?94 Firebird 3.4 - RIP<br />97 Firebird 3.8 - In the works
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...1 day ago
