my car is red and i want to get it repainted. it will be the same color but intead of getting the headlight area and grill area repainted black, i want to get those painted red also. once those are red, i want silver racing stripes. i have a 96 if i hadn't mentioned that. in my head it looks pretty cool but i dont want to do it and have it look retarded. thanks in advance for any input.
would this look alright
96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHRTags: None
I've seen it done, i think it looks better with the headlight area left black. A LOT better.-Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
some people like it...for me its the easiest way to tell the car got repainted...painters never leave that black its just more work...leave it black you'll be much happier
05' CTS-V
00' Camaro - SOLD :(
My dad is a Master Certified Automotive Painter....so i know all the little painting tricks of the trade. Painting the lamp area would look similar to what the current Corvettes look like. Compare it to that.
Also, repainting an entire car is more expensive than you think it is. Not only is it the stuff you see, its also painting the stuff you dont. Hood jams, door jams, trunk jams, all that good stuff. Racks up a lot of labor hours very fast. I suggest you get an estimate if you already havent....
would i realy have to get all the jams painted since its going to be the same exact color??96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
No you can keep your door jams, if its the same color or even a similar color just woudl have to if you did something like paint it silver or something.
I have seen it too I don't think it looks bad, I think its a mush for 93-97 white cars but red its all just about your opinion on it, woulnd't look good or bad. As long as the paint does fade on the black(like my car did) then it would look good. [img]smile.gif[/img]
i think it looks better painted. and no you dont have to paint all the jams such but it is the half assed way to do it and imo looks like shiit2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
i really like the way that looks. im not worried about the jams. i dont think it will look all that bad. its going to be the same color and the jams haven't faded because the sun doesn't hit them directly.96 3.8 red camaro. <br />headers,cam,valve springs,retainers,auburn lsd,3.73 gears,SLP cold air,accel coils,24lb injectors,8mm plug wires,air temp module,LT1 diveshaft,removed a/c,edelbrock torque arm,spohn LCA\'s and PHR
whenever i see a camaro with the black around the headlights painted the same color as the car, it makes me want to either puke or cry. i've seen it multiple times. one orange, one red, one blue. it all looks bad.1996 Pontiac <a href=\"http://www.fullthrottlev6.com\" target=\"_blank\">Firebird</a> <br />Black, 3.8L A4
i like it personally but to each their own. yeah if you are painting the same color dont sweat the jams, it would just be a lot of money for little appearance differences.2001 Arctic White Firebird With Black Drop Top<br /><br />3:42 Gears<br />Zexel LSD<br />BMR upper A-Arms<br />Trans Am exhaust with 3\" I-pipe and cutout<br />Modified intake<br />Mecham Hood<br />Trans Go shift kit<br />Making rear control arms and panhard
If your going to be sticking to the same color, then it would be cheaper just to get it scuffed down and re-cleared. Going this route you would not have to worry about the door jambs and whatnot. More than likly its not the paint thats in shabby shape its the clearcoat. If your gonna REPAINT certain areas that have deep scratches or require more body work or replacement of panels, then re-clearing the entire car will make it blend a whole lot better. If you have seen a car thats had a panel or two re-painted/cleared and the rest of the car left alone you'll see it looks like crap. Just getting it re-cleared is alot cheaper a local body shop around here (thats very good quality and usually quite expensive) quoted me about $2500 to $3000 to repaint the same color or color change, and only $800 to $1000 to just scuff (sand) re-clear and buff the origanal finsih. You see the diffrence?
just my 2 cents
JohnWhite 1998 Firebird M5, Suncoast WS6 hood, Chrome 18\" C5\'s, beaver tail wing, 2 15\" Kicker Comp VR\'s, ect.
