it seems that on my firebird the firebird and bird logo between my rear taillights is fading and looks kinda pink now. does anyone know how to remove it? i know if i try scratching it i will ruin the plastic around it. any ideas?
need help on firebird decal and phoenix logo
2000 firebird w68, auto, t-tops , 3.42 , k&n, whisper lid, taylor 8mm spark plug wires , bosch spark plugs , 3\"in/out carsound CAT , 3\" i pipe, take off trans am muffler, C6 Z06 rimsTags: None
Mines been pink for awhile =) Plastic "razor blade" can remove it if its a decal.00\' firebird v6 5spd<br />201rwhp ---- 230 rwtq<br />\"Everyday I grow stronger...and further from you.\"<br />WARNING: Do not take any of my comments seriously unless they are technical in nature and then only at your own risk
i just replaced my 'Firebird' on the back (with some decals from brent franker). my bird still looks ok. i will replace when it starts to fade. i put the bird from brent on my whisper intake -- vast improvement over the 3800II.
i did a little initial wet sanding with 2000 grit on the text. 1500 or 1000 is likely a better choice. 2000 takes forever but its what i had on hand. [i left just a hint of the bottom of the letters so that i had something to guide placement of the vinyl decal.] you want to remove any of the red and level the edges of the letters. when happy switch over to 3M Perfect-It II rubbing compound. the whole process takes about 20 minutes to remove the text.
if you dont think its smooth/level enough switch back to wet sanding and then use the rubbing compound again.
heat it up with a hair dryer or heat gun on low heat. be careful not to screw up the paint. once the decal is warm, it should be easy to peel away, use a razor blade or utility knife if u have to.\'02 W68 Pewter Metallic Firebird-RKSport Headers, Catco 3\" cat, SLP Loudmouth, Fast Toys ram air, K&N, !Air Silencer, shaved airbox lid, SLP fan switch, BMR strut tower brace
I wet sanded mine off. there are pics on my cardomain page... the pics I have still show it being a little scratched up but I got it really shiny by using a buffer on it. Its really glossy now like my tailights but I dont have new pics, sorry. I was thinking of getting a new decal for it but i am used to it plain right now.<a href=\"http://www.cardomain.com/id/maleet\" target=\"_blank\">1998 Silver Firebird</a> <br />Basic mods... nothing real special but it sure looks good!<br /><a href=\"http://www.maleetpobanz.com\" target=\"_blank\">maleetpobanz.com</a>
I took the easy way out and ordered a whole new filler panel from www.gmpartsdirect.com.I solemnly swear I am up to no good.
i think i found the cure. if u put wax on it it brings the red right up. a family friend had the same problem on his bird and i just tried it and worked. i'll try to get a pic of it soon.2000 firebird w68, auto, t-tops , 3.42 , k&n, whisper lid, taylor 8mm spark plug wires , bosch spark plugs , 3\"in/out carsound CAT , 3\" i pipe, take off trans am muffler, C6 Z06 rims
Re: need help on firebird decal and phoenix logo
I'm resurrecting this old thread to report that the replacement panel I bought (see above) has begun to show significant fading. So, I ordered a new "Firebird" lettering and bird decal from bfranker ($12) . I still had the first filler panel in the garage. I wet sanded off the factory stencil using 1500 paper. Then I polished up the panel using 3M Scratch Remover ($6). I applied the new decal and then installed the "new" old filler panel.
Once again, my filler panel looks great!!!!I solemnly swear I am up to no good.
lol you scared me for a minute dude. i didnt look at the dates and thought a few old members had come back.
Follow me!
Or this
