Does anyone know hot to adjust the hood? - FirebirdV6.com/CamaroV6.com Message Board
  • Does anyone know hot to adjust the hood?
    I have a 2001 camaro convert and i had a minor fender bender. no damage to my car but a little scuff mark on the front bumper. and the hood has a little gap on the drivers side. does anyone know how to adjust the hood?
    Jack
    If its sticking up too high or is too low you just turn the rubber pieces which the hood presses on and adjust it that way.
    If its off center side/side you need some mount work done on it to fix it.
    2002 5-spd NBM Camaro
    Details: www.1lev6.com
      You can also adjust the bracket that the hood latches on when it is closed, its two bolts i believe 10 or 12mm you can move it up or down.
      Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
