I bought a used 96 Camaro 3.8L and I am curious if it is an RS or not. How can I tell? What does the RS option include?
Is my 96 Camaro an RS?
I think in '96 the RS (Appearence Package) came with ground effects and RS badging. You'd be able to tell for sure if you checked the RPO codes.
http://tech.firebirdv6.com/rs.html
[ February 12, 2003: Message edited by: sac2165 ]</p><a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
Check for the Y3F sport appearance package RPO code... If you have that and RS badging, i'd say it's a safe bet [img]smile.gif[/img]1997 silver Camaro RS<br />|T-Type Powered|<br /><a href=\"http://www.kwfbody.com\" target=\"_blank\">Looking for a local F-Body club in K/W, Ontario, Canada?</a>
If your not sure than i guarantee it isnt an rs.Longtubes, true duals, ram air, caspers tps tec, ls1 26lb injectors, supersix powerpack, heads milled .020, comp cam .507 220/224 114 ls, forged internals and chromeoly pushrods, bored .030 over, tb spacer, tranny built with stiffer springs and kevlar bands, bigger servo, transgo stage 3 shift kit, edge 3600 stall, 1 pc aluminum ds, 3.73 superior gears, lsd rear ,custom pcm tuning, walbro 255 in tank,
Check for Y87 while your at it. That's a good thing to have too :D .<a href=\"http://community.webshots.com/user/maniacls1\" target=\"_blank\"><b>2001 Firehawk #155 of 504 -M6</b></a><br />437 RWHP / 404 RWTQ -Dynojet (heads/cam)<br />12.34 @114 mph 1.7 60\' (bolt-ons only)<br />12.47 @116 mph 2.0 60\' (street tires, heads/cam)
