wheel check - FirebirdV6.com/CamaroV6.com Message Board
wheel check
  • wheel check
    found a set of black Z06 wheels with a polished lip and without the rivets that i really like...i just wanted to make sure they would fit without rubbing or anything. they are 17x9.5 with a +54mm offset. will these go on my 94 and perform without rubbing the wheel well when i turn and stuff? and yall think these will go well with my car? pics on my cardomain in the sig. still thinkin ab these wheels and wanted to get other ppls opinions.
    1994 Camaro 3.4 L V6 <br />2.5\" Flowmaster 80 Series American Thunder Exhaust<br />SLP Cold Air Intake<br />Sony Head Unit<br />Pioneer Midranges<br />2 10\" Sony XPlod 1100 W Subs<br />Power Acoustiks 980 W Amp<br /> <a href=\"http://www.cardomain.com/id/heartbeat_of_94\" target=\"_blank\">http://www.cardomain.com/id/heartbeat_of_94</a>
    They fit on my 99 just fine. Don't see why it would be any different with your 94.
      I think the reason the question came up is because the stock '94 rims had different offsets. I remember that anytime one would come into the garage, we had to keep the rims in the same spot on the car when rotating the tires, which meant dismounting and remounting the tires. So it would make sense why a set four rims that all have the same offset would raise some doubt as to fitment.
      My '99 however does not have this issue... you can rotate the tires normally.
        what size tires would be the best for the set of wheels (17x9.5 / +54mm offset)?
          that's what I've got
            275/40/17s all the way around.
              Nice car! The Z06 wheels would look awesome with the white. I'd suggest 18's. I just got 18x9.5's all the way around and I am EXTREEEEEMELY HAPPY with them!
              2004 CE Corvette 10.86@132mph
              2011 Cadillac CTS-V
              2006 Mitsubishi Eclipse GS
                how much did the tires run for them? got any pics i can see? i've been fighting b/t 17's and 18's and still kinda deciding.
                  I have 2005 corvette wheels. 18" all the way around. I think tires were like $200 a piece.
                  <a href=\"http://www.cardomain.com/ride/857214\" target=\"_blank\">http://www.cardomain.com/ride/857214</a>
                    tires were $435 shipped for 275/40/17
                      ive got Chrome ZR1s for sale if you decide not to get those Z06 rims..
                      Mystic Teal Metallic
                      • Andy H
                        Transmission removal help!!
                        by Andy H
                      • 2.8 Bird
                        Abs inop
                        by 2.8 Bird
                      • fishin
                        by fishin
