If I were to wet sand my car with a 2000 grit sand paper, what would be a good wax to restore the shine and remove the fine scratches?
Scratches from wet sanding
there wont be fine scratches. use gentle force with the sand paper and a constant stream or water wherever your sanding. Before i wetsanded my car the paint surface was rough, kind of like rusty feeling.
I wet sanded it a while ago, with i believe 2500 grit or 3000 grit sand paper. dont remember. But as i was doing it, the water dripping off the car was turning rusty brown. After that, i washed it and waxed it and the paint looked and felt brand new. You may get swirl marks though on the hood and front fenders. To take care of those use 3M Swirl and haze remover.
Wet sanding is kind or.. you know, Do at your own risk.. i wouldnt recommend doing it unless you reallly have to like in my case. if not, just claybar the hell outta the car. anyways, goodluck96 Camaro M5. Dark metallic gree (?dont know the offical color name)<br />Home made Intake :: Headers, 3inch headers back to Flowmaster muffler :: spec stage 3 clutch Now installed, waiting for 3.42\'s and LSD next month<br /><a href=\"http://photobucket.com/albums/y192/RiceEatingCamaro/?action=view¤t=newcar.jpg\" target=\"_blank\">My Car</a> <br /><br />Totalled Car.<br /><a href=\"http://bellsouthpwp.net/s/k/sk8er305/\" target=\"_blank\">96 CamaroRS</a>
you will have some nasty looking swirls when youre done. the 3m stuff will take care of it, but like he said, do at your own risk. you can eventually rub through the clear/paint. but that takes a lot of sanding
Don't wet sand unless you really know what you're doing. Take it to a detail shop if you want something wet sanded.
As far as products go, Meguiar's clay bar kit or Meguiar's scratch-x would probably do a decent job to remove (or at least cover) scratches. Meguiar's NXT does a GREAT job of covering and removing swirls in my opinion. Great wax, but you should only use it about 4 times a year because its a cleaner wax.
If you want to go the pricey route, here ya go, this is the best: www.zainostore.com-Eric<br />2002 Navy Blue Camaro...Striped and Stalled. 35th Anniversary SS wheels <br />Best ET: 15.384 @ 88.32 on street tires<br />Project Whitney: Goal, 14.0 1/4 by summer 2008.
Wet sanding is usually done when a car is repainted, in between coats in order to get rid of any irregularities. (like dust specs that settle in the wet paint or clearcoat)
To get surface scratches out of your clearcoat use a good polish or clearcoat-safe polishing compound.1994 Firebird 3.4<br />15.65 @ 86.8<br /><a href=\"http://www.funkz.net/firebird.htm\" target=\"_blank\">funkz.net/firebird</a><br /><a href=\"http://mywebpages.comcast.net/funkz/timeslips.htm\" target=\"_blank\">Timeslips</a>
A. Whats the purpose of the wetsanding???
B. If you never done it before... try it on another car.. like the neighbors when they are on vacation
C.you will need to buff the paint. wetsanding dulls the paint, there are some good polishes out there if you look in the right place... Go to an automotive paint supply store.. they have the good stuff, what the professionals use.
D. Zaino is overpriced, and you can get the same quality from Mothers or Meguiars if you take your time.
So, unless you have some serious overspray, bad paint quality(orange peel, fisheyes, or dust in the clear) you can save yourself alot of work and the risk of a worse paint than you began by a claybar, some cutting finish compound and a good wax.
I do this stuff everyday and trust me, its easy to FUBAR a paintjob if you apply too much pressure or dont have enough water to clear the sandpaper.
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...2 weeks ago
by ssms5411So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...2 weeks ago
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...2 weeks ago
by AZ3.8CamaroI have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...2 weeks ago -
Well, I finally am getting some time to get back into these cars. Today I installed a set of no name eBay stainless headers that I’ve had for probably...4 weeks ago
