ok now both of mine are burned out, i need to replace the lights in them.
ok so how do i get to them, what kind of bulb, and should i worry bout the air bag?
you can get the bulb at radio shack it's a 12v clear bulb... part# 1092
to get out the switch just grab it and pull it towards you, just disconnect the wires from the back of the switches and take them into your house.
I used a small screwdriver to pop off the top of the switch.... I think there's 3 little clips holding it down.
To get the bulb out you have to remove the circuit board it's soldered to... this requires a very very small wrench... (I can't remember the size) then you just have to remove the little red condom from the bulb and use a soldering gun on the back of the board where the bulb connects to heat up the solder and remove the bulb.
then all you have to do is push the other bulb's leads back thru the hole in the circuit board where the old bulb was... (you have to heat up the solder again to do this) Clip off the excess off the leads and put every thing back together...
The hardest part of this is hooking back up the wire from your steering wheel... GM didn't give us much room to work with
damn thats quite a bit of work, i will have to try it out, thanks for the reply though, and the helpfull info, i miss those lights on the wheel :D it makes it look cooler ;)
Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...
So went out to start the Camaro and no start, batteries are good just hear a thud sound, started up fine last Friday. Check the fuses and the battery...
Working on getting my 99 Camaro back in action. Long story short, got parked in the garage about 5 years ago (kids, career stuff ect.) trying to get her...
I have a 15 year boy now (crazy how time flies from when I was a teenager on here!) and his first car will be the old Camaro.
I stopped driving...
