Need Help Under-Car Glow - FirebirdV6.com/CamaroV6.com Message Board
  • Need Help Under-Car Glow
    I got a Streetglow gold series neon underglow kit. I'm installing them and I need some help. I was told to install them inside the frame, but I'm running into a problem. There isn't enough room inside the frame on the driver's side, the fuel lines are in the way. Any help will be greatly appreciated.
    Polo Metallic Green \'96 Camaro w/Y87 Performance Package<br /><a href=\"http://www.cardomain.com/id/greenmaro24\" target=\"_blank\">Corey\'s Camaro</a>
    I told ya there were problems with installing them inside the frame.....
    put them in the little channel between the outside of the car and the inside of it.
    <a href=\"http://members.cardomain.com/leonwithneons\" target=\"_blank\">1997 Grand Prix GTP</a>
      If you have gfx on your car you can put them on those! Thats where mine are and they glow great!
      Derek <br /><a href=\"http://www.cardomain.com/id/dmiller_2005\" target=\"_blank\">2002 Metallic Silver Camaro</a><br />35th Anniversary
        I don't have gfx, I need a solution.
          About your only place to put them now is on the outside of your frame.... but they show there [img]graemlins/thumbsdown.gif[/img] I actually just got done about 5 minutes ago moving mine to the inside of the frame. good luck finding a solution
          1999 Camaro Silver 5spd<br />Appearence Mods:<br />-Clear Corners -Tail Lights off a 93-96 Camaro -Painted Black Calipers w/ Silver Camaro Decal on front ones -Black Camaro Rear Fill Decal -Silver Camaro Front Fill Decal -Painted Silver Interior Pieces -RKSport Shift Knob<br />Performance Mods:<br />-Eibach springs -Whisper Lid -Removed MAF screen -Free Ram Air -Trans Am Dual Exhaust -3\" Cutout<br />Stereo System:<br />-Eclipse 8v Head Unit -Eclipse 87series 12\' Subs -Rockford Fosgate 800wt amp (subs) -MTX 225wt amp (highs)<p>AOL IM is jay eub, msn messenger is banks_2003@hotmail.com
            How did you get yours to mount on the inside of the frame?
              it is a tight fit but it will work. what year is your camaro?
                My Maro is a 96. My friend has one the same year as mine and he just pushed his fuel lines over a lil' bit. Is that what you did?
                  Yeah, Im his friend, it was a pain in the butt, they are really tight too. I pulled the lines over, cut some sort of shield offa it and had to move the plastic mount that they go through. But all in all, it looks pretty clean and as long as the neons dont spontaiously combust and light up my fuel lines, I should be ok ;)
                  96 Artic White 3800 Series II Camaro <br />Mods: New Engine, SLP CAI w/ K&N Filterchargers, SLP Quad Center Exhaust, LS1 Aluminum Driveshaft, BFG G-Force T/A-KDW 245/50ZR16s, StreetGlow Gold Series Neo-Blue Under Car Glow, and Sony MEX-5DI Color TFT CD Player.
                    mine didn't have fuel lines running right there
