I've grown big enough balls 2 start pinting my interior. I have a 2001 firebird. I started w/ the rear speaker covers today. I hate that mesh stuff that's on the inside. The paint stuck to it and I had to sand it and the glue off. I was wondering how to take the power window/lock cover off, as well as the side pockets in the doors and the cover for the dook lock and handle. I worry about breaking anything. I noticed a screw holding the door handle panel and the pocket to the door. if I take these screws out, will they allow these pieces to pop out?
removing interior pieces
I am doing the same thing. The whole door panel comes off and not the seperate pieces unfotunately :( At least not the ones with clothe interior. Here's a small write up on how to remove the panels. http://www.carstereohelp.com/stereor...birdFDrPnl.htm
For some reason my panel is giving me alot of trouble then my console so make sure you do these things that I've discovered doing mine:
1.Sand the pieces down really well with 320-400 grit sandpaper.
2.Wipe them down with rubbing alcohol.
3.Spray Duplicolor's Adhesion promoter
Good luck doing yours.
-Michelle
Sand the pieces very well with2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
i just got done doing the intrior on mine. Door panels top of center cousole and more stuff. It looks bada**. I didnt sand anything, because i still wanted the orginal texture and it came out with no probs.1999 Pontiac Trans Am M6 Far from stock.....
<blockquote>quote:</font><hr>Originally posted by CamaroRob97:
i just got done doing the intrior on mine. Door panels top of center cousole and more stuff. It looks bada**. I didnt sand anything, because i still wanted the orginal texture and it came out with no probs.<hr></blockquote>
whoa, so you dont have to sand it and it still looks good?!?! i wanna see pics . . .
Arctc...the door panels are the same on the birds from 98-current as far as I know.
This is the console I just did.
And as you can see on my passenger side door panel there in that pic...look to the lower right and you'll see it's scratched :( I didnt sand down the panels and did them while they were still on the door which wasnt easy and I wasnt happy with the results at all so that's why Im doing them again.
[ February 17, 2003: Message edited by: Pewter2k Formula ]</p>2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
