On my passenger side where the front fender meets the door, the plastic sticks out, making the line look less smooth. I've seen this on other Camaros, anyone else have this problem? Dammit, its a 2002, it shouldn't have this problem. I already got a broken mirror, c'mon GM!!! :mad:
Annoying imperfection......
Have you or anyone jacked the car up. That usually happens when its jacked in the wrong place (its a block in my car). It happened to me years ago. It can be fixed with a hammer and piece of wood (and a good cloth). Sounds scary i know, but we did mine at the bodyshop like that.
-Justin2001 Camaro Z28 (A4) Sunset Orange Metallic w/ T-tops, Monsoon Stereo, factory GFX, BMR STB from the v6, 18K miles<br /><a href=\"http://www.cardomain.com/id/jhkcam22\" target=\"_blank\">2001 Camaro Z28</a><br /><br />Dads car: 2002 35th aniv. Bright red Z28, fully loaded<br /><br />R.I.P.<br />1995 3.4L Camaro (A4) Bright Red<br /><a href=\"http://www.cardomain.com/id/jhkcam\" target=\"_blank\">1995 3.4 Camaro</a>
Happened to me after a week. I took it back to the place that jacked it up & they said "it happens all the time", he used a big set of vice grips to straighten the metal out.<a href=\"http://www.cardomain.com/id/sac2165\" target=\"_blank\"> CAMAROS</a>
i have that problem on my driver side fender on my 99 bird. Its because the bracket underneath the car where your fender bolts up to is bent from hitting something. At least i know thats why mine doesnt line up perfect.
Have a look right in fromt of the door underneath the car, you will see that the fender rolls under the car kinda and is bolted to a bracket. Im betting that that bracket is bent for you. ;)99 Firebird Vert, Pewter Metalic<br />Fast Toys Ram Air<br />Jet Stage 2 Chip<br />17x8 Mille Miglia Emotion II Plus\'<br />wrapped in 245/35/17 Yokohama A520<br />Rhino Perf. Exhaust<br />K&N air filter<br />check pics at:<br /><a href=\"http://www.fastrides.com/members/v6birdy/\" target=\"_blank\">http://www.fastrides.com/members/v6birdy/</a>
Yup, has happened to me many times.
They jack on the fender tabs instead of the sub frames. Looks worse with the Trans Am b/c of the ground effects. I just fixed it and it happened again.
Now I have to crawl under there and fix it again :mad: .
Chris<b>2002 BSM TransAm WS.6 M6</b><br /><b>350rwhp, 365rwtq</b><br /><b>Stock:</b>13.455 @ 105.39 2.129 60\'<br /><b>Mod:</b>12.449 @ 113 1.832 60\'<br /><br /><b>2004 QSM GTO M6</b><br /><b>303rwhp, 329rwtq</b><br />Stock: 13.74 @ 102.14 2.1 60\'<br /><br /> <a href=\"http://members.cardomain.com/silvertaws6\" target=\"_blank\">http://members.cardomain.com/silvertaws6</a> <br /><br /><b>1984 Firebird S/E M5</b><br />2.8L
this happened to me too. i recently had gfx put on. i think the guy who put them on fixed it for me.
I took the Camaro to the dealer a few hours ago for this problem. The strange thing is that most of the fender lines up perfectly. The only part that isn't aligned right is the curved part at the top where it meets the mirror. It's pushed out and doesn't line up right.
Could this be caused by the bottom part being bent? It doesn't look like it could, because it's just at the top. Every other spot except for where it curves to line up with the mirror is perfect.<a href=\"http://webpages.charter.net/camarov6/Car%20Pics/New/IMG_0085.jpg\" target=\"_blank\">Black 2002 Camaro M5</a>-SS takeoff muffler, B&M Ripper, K&N Filter, 35/20% tint, Infinity speakers, Viper alarm, perpetually breaking clutch return spring mod. 15.49@90.15<br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P14.JPG\" target=\"_blank\">Pewter 2002 Firebird M5 (Dad\'s Car)</a>
there's a bolt there when you open the door that you should be able to see
you loosen the bolt a bit, then move the panel over and tighten the bolt again.
It's right there by the mirror when you look. I know my instructions are kind of vague, but you should be able to see what I mean when you look [img]smile.gif[/img]
I had to do this to my car aswell.
by 2.8 BirdI wish you guys the best for you and your family. Good health, happiness and prosperity. Merry Christmas and a happy new year....3 days ago
by ssms5411Just ordered some Toyo 315/35/17 tires for my 17x11 rims. Hopefully I can get them on the beginning of next year. Will post pics.3 days ago
by ssms5411Haven’t done anything on the Camaro, but put LEDs on my truck headlights . And my oil pressure sensor went out on the truck so going to fix that this...1 week ago
