painting interior.... - FirebirdV6.com/CamaroV6.com Message Board
  • painting interior....
    How have all you guys gone about painting your interior? I have wanted to but dont want it to look like ****, i want it to look good. What kind of paint should i use and what kind of prep work is involved, i also use armorall if that effects anything. I am thinking blue becuase my car is black and i have a blue theme going, but any other suggestions are welcome.. see the webpage for pics. Thanks
    1999 Black V6 Camaro<br />Website: <a href=\"http://midnight-maro.freestarthost.com\" target=\"_blank\">http://midnight-maro.freestarthost.com</a> <br /><br />CAI,Lid,K&N,SLP LM, Powerdyne, Shift Kit, 160* thermo, and gauge pillar w/gauges.. Sittin in the garage: RKSport Headers, Carsound Cat, LSD, Fuel Pump, GTP Injectors, 3.73\'s
    i just did mine. I still havent put it in but it looks soo soo good. I started off by taking of the vent covers, stereo cover, glove box door, auto shift knob, center console and center console box lid. They all come off easy. Only screw i remember are under the coin change holder in the console box. The others were under the glove box hinge.
    I washed with dawn, then sanded, then washed again andthen cleaned with rubbing alcohol. I tried a few paints first. Trim paints from walmart and clearcoat from walmart.The paint didnt look very good and the clearcoat gave it a white glaze.
    I painted over that with krylon from an auto store and a krylon clearcoat. Worked very good and gave a great shine. There is a finger print or 2 on the center console box, but other than that it is great.
    Be sure to tape, sand and clean it well with alcohol. Also shake, shake and shake your paint before using.
    I'll take pics of mine soon.
    (i also cleaned the shifter sliding pieces while i was there so it slides real smooth)
    97 RS<br />Member Status: F-Body Owner<br />Member Number: 7705<br />Registered: September 13, 2005<br />Posts: 24<br />Email Address: hfoxx123@yahoo.com<br />Location: Minnesota<br />Occupation: Database Administration<br />Homepage: <a href=\"http://none\" target=\"_blank\">http://none</a><br />Car: uh a camaro
      What'd you use to sand it, just basic sand paper?
      \'99 SSM Camaro V6 M5<br />(mod list on cardomain site; too long to list here)<br /> <a href=\"http://www.cardomain.com/id/v6cam99\" target=\"_blank\">http://www.cardomain.com/id/v6cam99</a>
        yeah sand paper works fine. i used a fine grit sand paper. it took a little longer but i was happy with the results.
        2003 Chrome Silver Nissan 350z 6 Speed<br /><br />2001 Bright Rally Red Camaro 3800 M5-----SOLD but missed
          I had my neighbor do mine, he owns a body shop. He just sanded them and then painted them the same color as the car with a small amount of clear coat. They turned out great and only cost me about $75! It is one of the best mods you can do to your interior!
          1997 30th Anniversary Camaro.
          SLP CAI, Dynomax, PCM tune, SS Hood, Clear Corners, T-Tops, Sony Xplod
          TEAM RED
            I am sticking with the Krylon. Everybody seems to want to spend mucho dollars on paint, when a can of Krylon and Krylon clear worked very well. My procedure was very similar to REDs. Remove part, sand with heavy grit, sand with light grit. 2 coats white primer, 2 coats red gloss, 1 coat clear. If the coats of red turn out orange peeled, I was wet sanding with about 200-400 grit. The only problem I was having was cracking, for which I just sanded back down and repainted. Not sure whether it was temperature and/or humidity related for I was doing parts all year round in the basement.
            Pics in sig
            Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
