Is tehre any reason that i should not bondo the little line that runs down the side of our camaros? the line that is right in the middle of the whole side, also what about on the bottom of the rear quarter panel? can i fill these lines in and expect there t be no cracking down the road from body movement?
Line on side of camaro filled in
If you are talking about the trim that runs along both sides of our cars. Then no I doubt u can bondo those strips and it look right, however a professional may be able to do it. A nice idea like my buddy did to his Z is to take off the trim which would make the car look cleaner if u like that sort of thing.01\'Y87 Firebird:Gt1 cam,Vig.3000 stall
www.vaperz.com
If you take the body molding off and look close, there is a crease down the side of the car that runs right along with the molding. I think he's going to get rid of all the stuff on the side, for a nice smooth look.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
make sure you block sand it. if you use just your hand on the sand paper and will make waves cuz of you fingers.<a href=\"http://cardomain.com/id/articacid\" target=\"_blank\">2002 35th Anniv. Black Camaro M5</a><br />Mods: Carsound Cat, SLP Loudmouth, Whisper Lid w/ K&N, J&M LCA\'s, ST Springs, eD Stereo(146.7 dB)<br />\'88 K1500 305 V8 Auto(Winter)
Yeah, for real, block sand it when you have everything filled in, cause you don't wanna look down the side of the car and have it all smoothed out, and start seeing waves in the paint. That would make everything pointless.~Chris<br />1999 Hugger Orange Camaro<br /> <a href=\"http://www.cardomain.com/ride/273836\" target=\"_blank\">http://www.cardomain.com/ride/273836</a> <br /><br />†…faith…hope
by Andy HHey everyone! I've been trying to remove my transmission for two days now! I need to replace the clutch. Only thing I've got left holding the transmission...2 weeks ago
by fishinI usually have to double, triple my headlight switch for them to come up on my 97 Firebird. I cleaned all connections. Could it be the headlight switch...3 weeks ago
