Did any body install a electric water temp gauge in a 3.4 camaro.If so how hard was it.What did you have to do.
want to no about water temp gauge
I have never read about anyone doing this. I was looking at a spare set of 3.4L V6 heads the other day and I think I came up wiht a VERY easy way to put the sensor in the passenger side cylinder head. I will look into it and post some more info shortly. Also, this probably should have been in General Tech.
EDIT: The thread pitch of the hole where the water temp sending unit on the driver's side cylinder head and the passenger side where the plug is is 3/8"-18. If you can find an adapter that has that thread on the outside and the sending unit that comes with the gauge can fit into the center of it, you're in luck. If you need more details, let me know.
[ May 13, 2003: Message edited by: viper98885 ]</p>- Josh<br />If you have any questions or need installation pics/help, e-mail me: Viper98885@aol.com<br /><a href=\"http://Camaroz28.cardomain.com/id/viper98885\" target=\"_blank\">\'93 Camaro Hardtop</a><br /><a href=\"http://Camaroz28.cardomain.com/id/01lincolnls8\" target=\"_blank\">\'01 Lincoln LS8 Sport</a><br />\'00 Yamaha YZF-R6<br /><a href=\"http://www.ftpp.net\" target=\"_blank\">Full Throttle Performance</a>
Thanks for the info,I guss i should have looked in to the install before i ordered it.What would be easer to install electric or machanical water temp,any way my buddy got a cam package off you i cant wait to hear it.EDDY MACLEAN
