How the hell do you get these out? I tried for a long time and could only get one out, and mangled it pretty bad. There's gotta be an easier way?
Front bumper cover retainer pins?
AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSDTags: None
<blockquote>quote:</font><hr>Originally posted by xjarayax:
How the hell do you get these out? I tried for a long time and could only get one out, and mangled it pretty bad. There's gotta be an easier way?<hr></blockquote>
Are you referring to those black clips? There's about four of them. Or something else? If it's the clips you are talking about, use a needle nose pliers and pull the middle part down, not the whole thing. If these are what you're talking about let me know and I can explain more. Otherwise, just ignore this.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
Yes I think we're on the same page, continue.AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
mmmk.
Here's a pic of what I think you are talking about.
CLIP
"There is a center "pin" which slides into the main clip piece. This keeps it securely in place. In order to be able to pry this clip out, the center pin needs to be pulled out slightly to release the pressure on the inside of the clip. With this clip installed, the center pin fits flush against the clip."
You will want a pair of narrow needle nose pliers to help pull the center pin out. If you can't grip it good enough, use a flat head screw driver and try to push it under it and pry it up.
Once you get one out and see how it's done, it's very simple. Let me know if you need any more direction.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
Thanks, why couldn't they had just used hex bolts :mad: :eek:AIM: escalier deverre<br />\'02 Pearl Blue Metallic RSX-S (daily driver)<br />\'98 Black Firebird<br />98 V6 turbocharged to 02 LS1 swap<br />\'02 LS1/4L60E<br />LS6 Block, LS6 Intake Manifold, Thunder Racing 215/220 .600/.523/115 Cam, Titanium Retainers, Crane Double Valve Springs, 125 shot NX Wet Kit w/ NOS brand Purge, True Dual \"H\" Pipe w/ two chambers and dumps, 17x11(rear) and 17x9.5(front) Black Powdercoated ZR1 Replicas on 315 and 275 BFGoodrich Comp T/A\'s (Street)/ET Drags/Skinnies on Weldlites(Track), 3.42/LSD
by ssms5411Had to be evacuated Monday again after a fire was going on the hill behind us. Only 3-4 hours, they did a good job getting it under control. Especially...1 week ago
by RPDRed6Up for sale is my 2001 Chevrolet Camaro 3.8 in need of some TLC and help. I’ve owned this vehicle the past 18 years (since 2006) and it’s been very...4 weeks ago
