How to remove the faded rear filler decal.. - FirebirdV6.com/CamaroV6.com Message Board
  • How to remove the faded rear filler decal..
    My autographics tail light filler decal has arrived...so....
    How can I remove the faded rear filler decal from my car without hurting the shiny black plastic?
    Thanks
    <blockquote>quote:</font><hr>Originally posted by silicuda:
    Thanks
    <hr></blockquote>
    welp....follow my instructions here . Look for Exterior and you'll see them. Ive done this now 3 times on some used panels :D
    http://www.dpics.us/MLB/MLBMods.html
    2000 Pewter Metallic Formula M6 <br /><br /><a href=\"http://flaminbird.smugmug.com\" target=\"_blank\">My 2000 Formula</a>
      Hi, yes I read that but im scared to wet sand. Can i just use a rubbing combound to disolve/remove it using a brush?
        Use Michelle's method, I did it to mine and it came out as perfect as hers did. I was a little worried too but it came out great.
        However it took me a good 45 minutes of 1500 grit to get it looking good.
        <a href=\"http://www.cardomain.com/id/HiWire\" target=\"_blank\">http://www.cardomain.com/id/HiWire</a> <br />1997 Dark Green Firebird <br />1997 White T/A
          yeah, i used 2000 grit sandpaper and it took about 30-40 minutes to take the emblem off. then i used 3M's fine cut rubbing compound to shine the panel back out. it took me about 6-7 coats of the rubbing compound to get it completly done. it looks great now though.
          2000 pewter firebird<br />Short Throw Shifter, Whisper Lid, Whisper Ram Air, Holley Filter, B&B Triflo, LSD, BMR LCA, STB, PHR, and sway bars (32/21).<br />Power window conversion
