2 piece gfx prob - FirebirdV6.com/CamaroV6.com Message Board
2 piece gfx prob
  • 2 piece gfx prob
    i got a front gfx clip for my front last friday and it came to me in two pieces. look cool and all, but, right dead center where the tip of the nose is where they'll come together. what do you think i should do??? a friend of mine who does some fiberglass work said he wouldnt recommend goin over it with fiberglass because of "body shifting". he said it would probably crack over time. so do you guys think im stuck with the crack in the middle or what? what would you do?
    2001 camaro v6 red convertable<br /> ggotta go fast... I GGOTTTA GO FFAST! CCANT HEELP MMMYYSSELLLF<br />pics:<br /><a href=\"http://www.cardomain.com/id/darkthoughts5000\" target=\"_blank\">http://www.cardomain.com/id/darkthoughts5000</a>
    what kit is this? i'd like to see what youre talkin about.
    Visit My F-Body Page
      if it cracks over time big deal, just do it again in a couple years.
      Whats wrong with bondo? or even JB weld.. glue would probably work..when you get it painted they should hook you up..
      1999 C5<br />2000 Ford Lightning<br /><i>Don\'t hate me because I\'m awesome</i>
        heres the pic, but its just the front part
        http://www.vizages.com/98camaro-info.htm
          looks like it should be one peice.
            ya, but its 2. put together, its very minimal, but it there
              Just glue it together at the joint.. I dont understand why that wouldnt work
                i just want to make it look as one piece. call me picky i guess
                  Just bondo it, chances are you'll hit something and break it apart before it'll crack natrualy. Either way your gonna have to be very carefull when you drive now, you'll be amazed at how terrible thats going to make every dip. I scrape like no other and the middle of the front is stock height, add what an inch or so and your goin very slow and at huge angles on anything. Beautifull kit though, I'd like to see some pics when it's finished.
                  1998 Red RS 3.8l A4<br />Whisper - K&N - N20 - Magnaflow muffler&Tips - 1LE Panhard - Ghetto STB - 255/50ZR16 Ecsta<br />Stull Billet Grille - Limo tint - blackouts - Black or Red \"camaro\" piece - A-pillar cf a/f ratio - Greddy fuel press<br />Panasonic DF88 - 1 12\" Eclipse 88120.4 - Eclipse 3322 amp<p><a href=\"http://members.cardomain.com/raven_rs\" target=\"_blank\">http://members.cardomain.com/raven_rs</a>
                  • Andy H
                    Transmission removal help!!
                    by Andy H
                  • 2.8 Bird
                    Abs inop
                    by 2.8 Bird
                  • fishin
                    by fishin
