GTS Headlight Covers - FirebirdV6.com/CamaroV6.com Message Board
  • GTS Headlight Covers
    Anyone ever have a problem with these from the COPS? I can pick up a used set for 20 CDN.
    EZD
    1996 Camaro
    i dont recemmend using them, if you have stock bulbs still. I would get the bright bulbs, then you should get be ok. Just for being able to see at night get the bulbs.
    1999 Pontiac Trans Am M6 Far from stock.....
      get the probeam series and it will be ok....
        From the 'Shwa huh? I'm from Newmarket, man!
        I used to have blackouts on my old Cavalier. I didn't get harrassed really, maybe it's 'cause I had those xenon look-a-like bulbs behind and always had either the DRL's on, or the headlights so you couldn't see them very well.
        -Andrew
        p.s. ever go to St. Thomas Dragway?
        1998 NBM Pontiac Firebird - LS1/T56 Swap | Pro-Kit Springs & Bilstein HD\'s | BMR LCA\'s | LG Adj. PHR | T-top Conversion | <br /> <a href=\"http://members.cardomain.com/battyv6\" target=\"_blank\">http://members.cardomain.com/battyv6</a>
          i got pulled over plenty for not having a front liscence plate and they never said anything about my blackouts.
          • Andy H
            Transmission removal help!!
            by Andy H
          • 2.8 Bird
            Abs inop
            by 2.8 Bird
          • fishin
            by fishin
