A REAL 93-97 headlamp set-up.... - FirebirdV6.com/CamaroV6.com Message Board
  • A REAL 93-97 headlamp set-up....
    Well,
    I happened to nab me a 95 Camaro with the 3.4L and the worst headlamps I have ever seen.
    After seeing some painful looking shortcuts with the factory headlamps, I lobbed Daniel Stern Lighting an e-mail (you can google for his page) and here's what came from him.
    Well, I'll give you all the meat, since neither of us have nice things to say about the four lamp system, since Sylvania designed it to be an EIGHT (8) lamp set-up or non-clear bulbs. It beats using driving lights, too. Of course, if you use them and it works, so be it.
    http://www.rallylights.com/hella/90mm_modules.asp#97300
    http://bellsouthpwp.net/m/u/mulgeary/Hella90/
    Daniel mentioned this way is somewhat pricey, but come on, reusing factory housings? Yowsers. 825 lumens from a $20 phony blue tinted bulb stuck in a crummy factory housing that will burn out sooner than you want or 2600 lumens from these for $15 each? 3/4ths the cost for over 3x the light? Yeah, tough call.
    Glad to be here, maybe this helps someone, but gotta save up and get my DOHC 3.4L swap ready, or maybe it will just be the aluminum headed OHVer that I will swap in. The factory OHVer is in pieces as it is. V8 and being a contortionist for a spark plug change isn't an option and the Ranger has an 8 plug 4 cylinder already....
    Good day.
    [ November 03, 2005, 02:30 AM: Message edited by: Alfred ]
    http://www.bfranker.badz28.com/94z/piaa.htm
      It says on his website that he didn't want the PIAA, because I guess they weren't bright enough.
      -Kevin<br /><a href=\"http://heinz.no-ip.com/Car%20Pics/IM000117.JPG\" target=\"_blank\"><b>\'96 White Camaro RS M5</b></a> <br />GTP Shortblock - T3/T4 -6psi Intercooled<br />Open Downpipe
        i love my hella 90m's, even though i dont have them aimed right at all they are hella bright!
        http://www.ilfba.com/forum/viewtopic...ighlight=hella
        -Aaron, AKA ATL2001<br />93 3.4L <br /><a href=\"http://www.ilfba.com\" target=\"_blank\">www.ilfba.com</a>
