im sure this has been discussed before or it might just be that i didnt play with it enough and it was getting dark, but the fogligh switch how exactly do you get it out, i got it out towards me but wires still ran through the cluster, how do i get it out the other way!!! it has grooves so it cannot go out the backside so.....
getting firebird guage cluster off
it doesn't go out the other way. just pull the wire out a little more (there should be some slack in it) and you should see a male and female connecter. you can disconnect it from there and take out the switch. the connection might be conceal by a small strip of foam insulation wrapped around it...that how mine was...just unwrap it and disconnect the ends.
The whole thing. Pull the wires out a little. You should have about 5" of wires then a set of connectors wrapped in foam "noise" tape (prevents the connector from bouncing around inside there).<a href=\"http://members.cox.net/95batmobile/d86f.jpg\" target=\"_blank\">Sinister Six</a> <br /><b><a href=\"http://www.cardomain.com/id/c_o_jones\" target=\"_blank\">Cardomain</a></b><br />--This doesn\'t change the fact that I am ~The Guru~ who still kicks puppies...
