Triple Gauge Pod - FirebirdV6.com/CamaroV6.com Message Board
Triple Gauge Pod
  • Triple Gauge Pod
    Does it actually go over the existing plastic on the a-pillar or do you take the existing plastic off and replace it with the a-pillar pod?
    And what would be the best size to get? the 5/8 or 1/16??
    <a href=\"http://www.cardomain.com/ride/2038380/5\" target=\"_blank\">http://www.cardomain.com/ride/2038380/5</a> <br />pacesetter hi-flo cat, slp loudmouth 2 w/3.5 slash tips<br />Springtech lowering springs 1.75 drop<br />Hurst sts w/ short-throw stick<br />Not yet installed-pacesetter headers<br />Zexel-torson lsd<br />3.73\'s
    the ones i have seen go over it, but im sure someone out there makes a full replacement...
      i have a 3 gauge piller that goes on top. i'm sure that it could take the place of it. but since i don't have t tops (the the present moment) i moded it up to fit my car. since they only make them for t tops. check out http://www.egauges.com/
      WAWA-A-HOLIC
        Just trying to understand ... I have a convertible and it is easy to remove the A-pillar. Is the color the same with the rest of the interior? room? How are you running the wires?
        Thanks in advance
        Zaino; FireBatCave Decals; Red Inside<br /><br />K&N Filter & Lid; Removed MAF screen; FRA; Raised Air Box; 180°F Stat; BMR STB; 3\" Catco & S-pipe; Borla Cat-Back; O2 Sim; HPPIII; NGK TR55s; Taylor 8mm wires<br /><br /> <a href=\"http://www.cardomain.com/id/cbass300\" target=\"_blank\">http://www.cardomain.com/id/cbass300</a>
          http://www.turbov6camaro.com/images/P8060997.JPG
          i replace the hole pillar with it
          2 reasons
          mor room for guages and wires and it was 10x easier to install... also those crappy clips get old after you remove them a few times..... now i only have on screw holding the thing up and it fits almost perfect........ the littel round thing for the heater vent dont fit very well. well not at all.... i just cut the old one off
          1997 3800 Series II Camaro
