One of the bulbs in my fog lights went out and I have no idea what the size of the bulb is and I am not sure even how to take the fog light apart to get to the light, I heard of people getting brighter bulbs to put in there, what kinds do some of u guys use? THANKS ALOT KEVIN
How to change bulb in the fog lights on a 93 camaro?
-FLOWMASTER 80 series exhaust dual out,K&N air filter.<br />-Bright Rally Red, 1993 Camaro V6 automatic. No BIG mods yet! But who needs alot of mods when you have 160 hp? Kumho ECSTA Supra 712 tires 245/50-16\'s \"Great tires\" <br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P13.JPG</a><br /><a href=\"http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG\" target=\"_blank\">http://webpages.charter.net/camarov6/Car%20Pics/P23.JPG</a>Tags: None
Look in your owners manual for the bulb #.
It is easy to change. You don't need to go under the car at all. Just unscrew the aiming screw and pull two clips out on each side of the housing. It will swing open and you can replace bulbs. If you don't want to approach it that way, you can always go from under the car and behind the fogs. That's more of a pain though.94 Camaro 3.4 A4 <br />T-Tops<br />In the process of an LS1 swap.
yep, do it from the front. a needle nose pliers might help. dont drop the clips in the car.
Don't know how y'all do it so easily from the frontI wanted to hack the front of the nose off once because the retaining screws were hard to reach, then I lost two of them behind the nose of the car :mad:
Next time, I'll buy another camaro with working foglights instead of replacing the bulbs... :rolleyes:
-Marcsigpic
by ssms5411About a week ago noticed my brake lights not working also Hazards not working. Installed new brake switch and still not working, checked fuses and what...20 hours ago
