Boost Controller & Turbo Timer Pics - FirebirdV6.com/CamaroV6.com Message Board
  • Boost Controller & Turbo Timer Pics
    I finally got it all together and working right...well, at least without the momentary switch installed yet, but I have the wiring diagrammed out so it can go up and down with one switch. Let me know what you think.
    http://www.cardomain.com/memberpage/772299
    1994 Camaro: Firebird Interior, 3.4L to 3800 converted, OBD2 converted, A4 to M5 converted...In the turbo retirement home...<br /><br />1994 Mustang GT: 347 Forged Stroker, Port Matched Edelbrock Heads and Intakes, Tremec 3550 T-5, Spec Stage 2
    i like the idea of putting in the firebird dash, it looks a hell of a lot better than the camaro dash and allows for guages to be mounted in the a/c ducts like you are doing. Hope it finishes up without any problems.
    • Andy H
      Transmission removal help!!
      by Andy H
    • 2.8 Bird
      Abs inop
      by 2.8 Bird
    • fishin
      by fishin
