chrome rims question - FirebirdV6.com/CamaroV6.com Message Board
  • chrome rims question
    Hey I have a 2002 firebird with the 16in chrome rims. I was polishing them the other day and notied that they are starting to crack and bubble around the ABS sticker. Someone told me it could because the bolts on the wheels are torqed too much? if any of you can be help thanks
    i find it very hard to believe that would cause them to crack. sounds to me like the chrome is just wearing off. dirty chrome rims will chip after time, and if its not a great chrome job, they will begin to chip after a while anyway.
    Visit My F-Body Page
      thanks man...... yeah it must be a crappy chrome job because it is an 02 and I take good care of my rims
        Do you drive it in the winter?
        Pull the rim off and look at the back side, inside. Remove the ABS cover and clean EVERYTHING. I had to get rid of a rim where the chrome split, due to road salt corrosion.
        Raven
          yes I drive it in the winter but I try to clean them as often as possible in the winter...alright Ill try that. I dont understand what would make it look like its bubbling in some parts
            You clean the OUTSIDE, not the INSIDE. The salty water gets behind the ABS cap, inside the wheel.
            Raven
            • Andy H
              Transmission removal help!!
              by Andy H
            • 2.8 Bird
              Abs inop
              by 2.8 Bird
            • fishin
              by fishin
